Author: Subject: Poly bushes.
Kev1n
posted on 5/6/22 at 05:31 PM Reply With Quote
Poly bushes.
Hi everyone.
Does anyone know what size poly bushes are required for a velocity xt.
I have taken one out and measured 42mm long but can’t seem to find any that size ?
Thanks in advance.
Mr Whippy
posted on 6/6/22 at 12:50 AM Reply With Quote
I don't think they have to be exactly that length. So long as they both fit and the diameter is correct, a few mm either way inside the tube won't make any difference.
posted on 6/6/22 at 09:55 AM Reply With Quote
Agree in principle with Mr Whippy here it's the inner and outer Ø fit on the crush tube and wishbone that's more important than the exact length of them.
posted on 7/6/22 at 07:00 AM Reply With Quote
Whichever poly bushes you choose make sure the crush tube is long enough for the job. Crush tube issue is a well known problem , I suspect a lot of wishbone failures are down to it?
posted on 7/6/22 at 10:21 AM Reply With Quote
Good point rusty, the wishbone should be able to rotate, but not slide back n' forth in the chassis bracket.
In some cases it can pay to buy a set of poly bushes with crush tubes to ensure the correct fit. That also means you start with new crush tubes that don't have any corrosion on them.
Mr Whippy
posted on 7/6/22 at 11:52 AM Reply With Quote
stainless being the best but rare. Plenty of grease is a good solution and I like packing the gap between the bushes before inserting the tube
That sounds rude but isn't meant to be
Gersen
posted on 19/1/23 at 10:41 PM Reply With Quote
Day late and a dollar short - but for future reference.
From my XT they are:
45mm long and a 29 mm diameter polybush.
I picked up these to replace a damaged one.
https://www.duraflexpubushes.com/haynes-roadster-locost-wishbone-bush-pair-42-p.asp
Oh and defo had to use large washers to shim the wishbone to the mount size correctly - shout if you need a photo!
[Edited on 19/1/23 by Gersen]
