Author: Subject: Sierra alternator and luego loom
the moa 2
posted on 28/3/05 at 04:38 PM Reply With Quote
Hi ive search but cannot find anything to help explain how to wire up my alternator from the luego loom.
I have a standard sierra pinto alternator which i have unplugged which has two red cables and one thinner blue wire (all are un labelled, my luego loom has one wire for the alterntor so what do i do ?
I have found some previous posts and one explains how to install daihatsu charade alternator which has three connections coming from it one is the main + one is ignition + and one is battery charge warning light.
Im presuming that the one wire from my loom is switched ignition live and that im gonna have to get the main + spliced from the main brown cable in the loom and from there i dont know what to do with the thin blue or even which of the two red cables are switched and permantly live.
Please help surely this is an easy one to sort.
Cheers.
the moa 2
posted on 29/3/05 at 04:32 PM Reply With Quote
Have found that the two red wires are to go to battery and the blue goes to the luego loom which goes to your dash as a warning light .
