APR
posted on 12/4/05 at 01:50 PM |
sva first test failed
But back on wednesday
Failed on
1/ bolts on steering wheel not radiused ( used countersunk allen key bolts ) ??????
2/exhaust clamps contactable ( needs exhaust rap)??
3/frount wings not big enough to cover rims) ???
4/ forgot to pin brake bias bar (doh)
5/ rear fog lamp had no warning lamp when on
locoboy
posted on 12/4/05 at 01:56 PM |
Well done,
Not many things to sort though and all pretty simple, you will be on the road very soon and in a nicely sorted car too by the looks of it.
Locoboy
Kitlooney1000
Bad luck mate,
Still an easy list to sort, Get the retest booked asap, sometimes they get too busy and you wont get one for a month or so.
Good looking car.
Lew
Doesnt matter what Sh*t life throws at you, there is always some other poor bugger worse off!!!!!
mookaloid
posted on 12/4/05 at 01:58 PM |
Doesn't sound too bad, better luck next time
DaveFJ
posted on 12/4/05 at 02:49 PM |
No mention of a lock of a centre rear view mirror? I thought that was needed ?
car looks good
Dave
Avoneer
posted on 12/4/05 at 04:18 PM |
Bad luck mate.
Just my thoughts:
1) Most wheels generally need a padded cover.
2) It's the bolt through the exhaust clamp that normally causes problems, not the pipes themselves - ali plate around the clamp or nut covers on
it.
3) The front edge of the cycle wing needs to be further forward than the front edge of the rim (not including the tyre) in a vertical line.
4) Doh!
5) Easily solved.
Hope that helps,
Pat...
Danozeman
posted on 12/4/05 at 09:02 PM |
Well done mate. Theyr relativley easy to sort....
Looks a nicely finished car....
Dan
G3OFF
posted on 13/4/05 at 08:18 AM |
unlucky... but most of us have been there..
it wont be long now though before your done and dusted
no such thing as to much power......
APR
posted on 13/4/05 at 05:15 PM |
all passed here we go!!!!!!!!
Danozeman
posted on 13/4/05 at 05:33 PM |
Good man. Feel good?
Dan
APR
posted on 13/4/05 at 08:30 PM |
damn good
