Author: Subject: Custom Length Alternator Belt
stevebubs
posted on 8/5/05 at 08:52 PM Reply With Quote
Where from? Need a non-standard length belt for my Zetec installation.
macspeedy
posted on 8/5/05 at 08:56 PM Reply With Quote
halfords
stevebubs
posted on 8/5/05 at 09:00 PM Reply With Quote
Originally posted by macspeedy
halfords
Was in there today....a chocolate T Cosy would be far more useful than the idiot in their "parts" dept.
Gave up trying to get any sense out of him and bought 3 of their "standard" belts, none of which fitted and I've got to take back tomorrow.
paulf
posted on 8/5/05 at 09:06 PM Reply With Quote
Look in your yellow pages for an industrial transmission and bearing supplier, they will be able to supply one to suit and will have experience of measuring etc.
Paul.
907
posted on 8/5/05 at 09:12 PM Reply With Quote
Hi Steve
Fenner belts are made in Bury St Edmunds, Suffolk AFAIK
web site www.wyko.co.uk
HTH
Paul G
davidwag
posted on 8/5/05 at 09:17 PM Reply With Quote
Try a local motor factor.
I assume you are after a poly V type belt, if so the part no. will be for instance 6 PK 860, where 6 is the number of ribs and 860 the length in millimetres.
stevebubs
posted on 8/5/05 at 09:32 PM Reply With Quote
Originally posted by davidwag
Ta. I'll try Camberley Autofactors tomorrow. May need to try 2 or 3 to make sure I get the right length
dave dickson
posted on 8/5/05 at 10:24 PM Reply With Quote
Ill second the Halfords suggestion.
I have been there a few times with non-standard installations and just rummaged through the fanbelt display looking for the right length.
They operate (or used to anyway) a similar part number system as described above for the belt length.
My local factors got all upset at having to actually do some work to find a belt rather than look it up in a book, so I just did the searching myself in Halfords.
stevebubs
posted on 8/5/05 at 10:49 PM Reply With Quote
All I can say is that you Scots must have better stores then us Southerners...the only belts they had of the right width were 1463mm (hb1463g) and 1650mm (hb1650g) - a big jump. There was a narrower one at 1520mm (hb1520e) (still too big) but that was the grand total of belts in the store of approximately the right length.
From the book it looked like they could get FAI belts of varying sizes but nothing in stock and guy behind counter was missing a few spare parts in the customer service department.
[Edited on 8/5/05 by stevebubs]
mangogrooveworkshop
posted on 9/5/05 at 02:20 PM Reply With Quote
mac lives a small blat from a supersized halfrauds........... that well known pedalbike shop that sell some car stuff as well. The laugh is you go to partco to by the same stuff.
wheelsinsteadofhooves
posted on 9/5/05 at 02:38 PM Reply With Quote
remember this from a while ago, some mentioned
"Falcon Automotive belt part code 6FR870 (870mm length)"
not sure what supplier but maybe worth a google. presume it also comes in different lengths.
hope this is of use
James
posted on 9/5/05 at 04:13 PM Reply With Quote
Steve,
That's where I got mine from- but then I was after a 'v'pulley so maybe that's easier to find.
Having failed with the string route (it goes too far into the groove ) I just cut the Sierra belt down to the right length then opened it up and measured it. Bought an FAI one to match.
HTH,
James
P.S. I work quite near the 'original' CAF if it helps and you want something picked up/sent.
EDIT: Pulley changed to belt!
[Edited on 9/5/05 by James]
stevebubs
posted on 9/5/05 at 05:15 PM Reply With Quote
Steve,
Having failed with the string route (it goes too far into the groove ) I just cut the Sierra pulley down to the right length then opened it up and measured it. Bought an FAI one to match.
HTH,
James
Thanks James - I've a small branch less than 5 minutes from home and 10 from Work. Popped in there today. Closest sizes they do are 1488 and 1513. 1488 too small and 1513 a fraction too large.
Think I may need to change my design a little. Going to have a rummage around the escort / mondeo bits in my garage in a bit.
Think I may be able to make the 1513 fit without too many issues.
Stephen
posted on 9/5/05 at 06:20 PM Reply With Quote
My wife drives for a local parts supplier on Saturdays and sometimes delivers to Halfords . Always seems odd for a nationwide firm.
aweekes1
posted on 9/5/05 at 06:27 PM Reply With Quote
Why not use a belt that's slightly too large with a tensioner? It can't be hard to build a small wheel on a bearing on a dprung arm? ( I think the Mondeo v6 may have an arm you could rob)???
James
posted on 9/5/05 at 07:18 PM Reply With Quote
Steve,
Do you have no adjustability/tensioner on the alternator anyway? That 26mm difference between those two belts I'd have thought would be within the range of the alternator pivoting on it's mount.
Or are you in danger of it hitting the 'Y' rails?
James
Mark Allanson
posted on 10/5/05 at 06:13 PM Reply With Quote
Just wrap masking tape around the pulleys as the belt would run, cut it off and measure it
