Author: Subject: Viento rear hub carriers
darrens
posted on 30/5/05 at 03:00 PM Reply With Quote
Anybody any idea which way these go on as the ones I have are different to what's shown in build manual
Long sloping edge to the front or rear??
Darren
Snuggs
posted on 30/5/05 at 03:18 PM Reply With Quote
Either way.
Depends if you want the calipers forwards or backwards.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
Paul (Notts)
posted on 30/5/05 at 06:26 PM Reply With Quote
I placed mine with the long sloping edge to the rear so that the callipers are at the front of the hub carrier.
reason why - dont realy know, but the disc shot in the build manual on CD has them this way round. ( you need to enhance the image to see this)
wilkingj
posted on 31/5/05 at 04:52 PM Reply With Quote
Most have the Calipers on the front side, ie upside down.
This makes them hard to Bleed. (Take them off Bleed right way up, and refit upside down)
However, the Handbrake cables run much smoother with the calipers on upside down.
Sierra normaly has the handbrake cable very low down. however Locost Velocity Viento etc, has the cables coming out High, ie Over the Diff, then they would have to Dive down Under the hubs to get to the attachment point if the calipers were the right way up.
So... Bleed them properly,as you dont do it very often, but you would use the handbrake all the time!
Best Regards
Geoff
http://www.v8viento.co.uk
darrens
posted on 31/5/05 at 06:18 PM Reply With Quote
cheers for that fellows!!
