sinx
| posted on 12/1/03 at 09:26 PM |
Plans - Locost
Luego Team: I would like an independent rear suspension Locost chassis, BUT, mad as I am, I want to build/weld it myself. Do you do any plans - I have
the Ron Champion book which has been thoroughly dissected! yours sinx
Findlay234
| posted on 13/1/03 at 09:13 AM |
luego are a commercial company. im sure theyre not gonna start distributing their irs designs around. someone could copy them and start selling for
themselves.
luego do an irs kit in which you get all metal pre cut. all you need to do is weld it as per book.
or try some of the plans on http://www.locost7.info
cheers
fin
Luego Sports Cars
| posted on 15/1/03 at 06:09 PM |
IRS DIY Chassis
Cheers Findlay you are spot on. Hi sinx, yes we do a DIY IRS what we do is give you a basic IRS instruction sheet. We also tack the IRS end up for
you to fit. The cost of this is £225 + VAT. This does not include wishbones, floor, roll bar or any of the brackets. Best regards The Team.
sinx
| posted on 15/1/03 at 07:34 PM |
IRS Plan
Finlay anf Luego team, thanks for the reply, it makes sense! Only going towards the IRS because Escorts are becoming hard to find and IRS leaves more
options for the donor, sinx
