Steve Lovelock
posted on 12/9/05 at 07:50 PM |
Route of loom / pipes
Just about to fit the loom and the pipes in the transmission tunnel and was wondering if everybody sticks the suggestions of Luego. I ask this
because the project build in Which Kitcar mag said that he moved them to a different location. This is the Velocity.
wilkingj
posted on 12/9/05 at 08:22 PM |
Keep the petrol pipe as far away from everything else... especially the electrical loom.
A lot depends on where your tank outlet is, and where the filter / pump is and its relation to the engine... Sit and think a lot before you actually
do anything.. saves you doing it twice!
Best Regards
Geoff
http://www.v8viento.co.uk
Steve Lovelock
posted on 13/9/05 at 05:24 PM |
Well, I haven't decided what engine and tank to use yet so that will be difficult. I was planning to follow the Luego recommendations but
thought I'd double check first.
MkIndy7
posted on 13/9/05 at 08:00 PM |
Not sure if Luego have suggested it, or if its possible with and plugs etc on.
But some conduit or plastic trunking might not be a bad idea,
then the wireings protected and you can get additional wires through if you need them when its all built
coovey
posted on 13/9/05 at 08:20 PM |
I have followed theirs is most places.
There are loads of pics of the runs on my website (see below) That may help. I had no problems at SVA only compliments
