Author: Subject: Fuel Line Photographs
Dave Write
posted on 1/11/05 at 08:13 AM Reply With Quote
Hello All,
I have got to the stage that i need to install the fuel lines, has any one got some photographs of their installation of the fuel lines in a Luego Book Chassis??
Dave
DanP
posted on 1/11/05 at 12:24 PM Reply With Quote
The photos on the online build manual for the velocity are what i used to do mine last week (there are some decent shots if you look in the fuel pump and tank stage (stage 6). are you using carbs or injection?
HTH
piddy
posted on 1/11/05 at 06:37 PM Reply With Quote
You could also look here.http://www.coovey.com/velocity/
In October section
[Edited on 1/11/05 by piddy]
Dave Write
posted on 2/11/05 at 07:48 AM Reply With Quote
Thanks for the replies, very helpful!
Another idea I had was to run the fuel lines under the floor pan, and protecting the lines with polyethylene (plastic) strips running parallel with the fuel lines, thus giving it a 'wear strip' so that if the car does knock the floor plan, the fuel lines are protected from any damage. I have a friend building as well and he said he saw that the Westfields fuel lines run under the floorplan and they are proctected, how I dunno, he never managed to see under the car.
Has anyone ventured this road previously, or any suggestions would be greatly appreciated.
Regards
Dave
