DanP
| posted on 22/11/05 at 09:03 PM |
Heres a tip for people early on in their viento build....
This will definitely save you some trouble if you have a viento (and poss other luego's)...
make life easy for yourself and ream out all of the powdercoat etc from yhe suspension mounting brackets (so that the holes are 12mm dia) BEFORE you
fit all the metal panels as its a pain in the @rse doing it after they've been fitted!!
cryoman1965
| posted on 23/11/05 at 09:51 AM |
Seat Belt Anchor Points
It is also wise to apply this idea to the lower anchor points for the seat belts on the MK Indy BEFORE you fit the floor.
Its probably a good idea to ream all threaded fittings on a Powder coated chassis before you start your build.
