Johnmor
posted on 22/1/06 at 10:39 AM |
Taper for front ball joint
I'm still try to reach the rolling chassis stage and i need to modify the taper on my sierra hubs to take the Maxi ball joint .
Popping to luego is not an option (450miles). Does anyone know where I can get a taper drill of the correct size, or how they dealt with the same
problem?
Snuggs
posted on 22/1/06 at 11:06 AM |
I had the same problem.
Local engineering firms would do it but would need to construct a jig to hold the hub at the correct angle.
I was quoted £70 for the correct sized taper drill from a number of local suppliers.
In the end I went to Luego (260 mile round trip).
Probably the cheapest option would be to post to Luego and get them to do it.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
