Steve Lovelock
| posted on 23/2/06 at 10:19 PM |
Steering column lining up all wrong
I have just finished fitting the scuttle panel and put the steering column in to line up the brake pipe feeds from the brake reservior. I noticed
that the steering column is sitting really deeply into the scuttle, to the extent that the indicator stalks will be behind the dash panel which cant
be right. Have I missed a trick somewhere?
APR
| posted on 23/2/06 at 10:53 PM |
if you get the sierra ajustable column you dont have this problem. i ended up fitting some ally spacers 1" long between the mountings
Danozeman
| posted on 24/2/06 at 07:15 AM |
OOoh err ill have to check mine when i get home Ive got the same stuff. Looks like some spacers will be needed.
Dan
Paul (Notts)
| posted on 24/2/06 at 01:00 PM |
Have you double checked the position of the nose cone bonnet and scuttle to make sure the scuttle is in the right place.
can only compare to my Viento but the face of the scuttle looks very close to the brackets.
[Edited on 24/2/06 by Paul (Notts)]
APR
| posted on 24/2/06 at 05:45 PM |
pic of spacers which were turned down to fit inside of steering bracket
Steve Lovelock
| posted on 24/2/06 at 07:44 PM |
Spacers look brilliant, thanks for the idea. Was 1" enough distance to bring it out by?
APR
| posted on 25/2/06 at 01:14 PM |
yes look at dash layout in my photo archive
