kurt
posted on 25/2/06 at 03:54 PM |
Hazards, fogs, brake test to R1 loom???
I'm trying to work out how to add hazards, fog lights and brake test to my R1 loom which I have extended for all other lights etc. without the
use of a Vicky Greenloom or anything else. After trying to work it out from the Haynes Sierra manual, I've drawn a blank and need help.
Somebody out there must have done this. Some wiring diagrams would be a great help.
Cheers, Kurt
smart51
posted on 25/2/06 at 04:07 PM |
For your Fog light just take a wire from the fused 12V, say from the headlight switch, wire through a fog light switch, to the fag lamp and then to
ground. easy.
k33ts
posted on 25/2/06 at 04:59 PM |
http://hellfire.locostsites.co.uk/hazard_circuit.jpg
this is off hellfire website if any help to you, although the only comment about it would be i wouldnt put the warning lights in series
looks complicated but if youve got indicators working already its just a case of making both indicator circuts with one switch
[Edited on 25/2/06 by k33ts]
kurt
posted on 25/2/06 at 06:09 PM |
Do I not need a relay rather than take the power through the switch for the fog light, or is this not necessary? I'm just checking I'm no
expert.
k33ts
posted on 25/2/06 at 06:27 PM |
depends what sort of switch your using but normaly it will be ok without a relay just a fused supply nomaly from headlights so the fog only works when
the lights are on a single 21w bulb will draw less than 2amps
