muzchap
| posted on 12/3/06 at 11:08 PM |
Nose Cone Mounting (Advice) Luego Velocity XT
Hey,
Just looking for some inspiration really - been cracking on with the build and now starting to do the bodywork
Bloody Fibreglass is 'itchy/scratchy' - thought I'd caught summit off a bird at first
Anybody found any clever ways to mount the Luego nose cone - I want it to look neat and not drill through the sides etc..
Murray
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Paul (Notts)
| posted on 13/3/06 at 07:36 AM |
Made two metal brackets for the front and rivnuted them to the chassis. Then fitted rivnuts to the brackets so that I could use dome headed bolts
from the underneath to fit the front of the cone. Top area is just bolted through but intend to change this soon
Paul (Notts)
| posted on 13/3/06 at 07:37 AM |
from the front
Paul (Notts)
| posted on 13/3/06 at 07:38 AM |
with pic
Danozeman
| posted on 13/3/06 at 08:36 AM |
MIne will be mounted like that too. With a couple of bolts into rivnuts on the topchassis rail too.
Maybe hinged at the bottom with some sort of hand tightenable bolts up top.
Dan
muzchap
| posted on 13/3/06 at 10:04 AM |
Thanks Paul
There's some inspiration there :-)
