Author: Subject: Velocity headlights
piddy
posted on 26/4/06 at 09:28 AM Reply With Quote
Velocity headlights
Has anyone else encounted this problem with the headlights at SVA?
Front headlights did not meet the angles of visibility (a problem with the Luego setup so will have to modify)
Cured by.
Front headlights angles - moved the bar out towards the wheel by about 20mm and added a spacer under the lamp to get it up about 25mm.
This information was found on this chaps
Website
[Edited on 26/4/06 by piddy]
muzchap
posted on 26/4/06 at 10:27 AM Reply With Quote
Piddy,
Is this because of the lightbar mounting - or the actual headlights themselves?
I plumped for some Carbon Effect ones from SVC?
Murray
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
piddy
posted on 26/4/06 at 11:44 AM Reply With Quote
He doesn't really say.
I tried to e mail him but the contact link didn't work.
I've 5 3/4" black ones from Mac1.
