Author: Subject: 0-60 on a 2.0 pinto
matt page
posted on 30/8/06 at 09:21 PM Reply With Quote
0-60 on a 2.0 pinto
does anyone know what sort of 0-60 time a 150bhp 2.0 pinto will do??
cheers
matt
se7ensport
posted on 30/8/06 at 09:28 PM Reply With Quote
ballpark of 5sec in a 7 style kit.... google 0-60 calculator, you input weight & bhp and it'll give you an approximate guide.
matt page
posted on 30/8/06 at 09:31 PM Reply With Quote
yep. its a 7 style car.
cheers mate
Just
posted on 30/8/06 at 10:36 PM Reply With Quote
150 bhp is a lot from a 2.0 - is that definitely RR measured?
andyharding
posted on 30/8/06 at 11:00 PM Reply With Quote
I can beat a VX Turbo in mine.
Once I have the ignition sorted and rolling road I reckin mid to low 4 should be do-able but I'm pushing a lot more than 150bhp.
DarrenW
posted on 31/8/06 at 08:05 AM Reply With Quote
Depends on gearing, launch technique etc. My pinto is std apart from diy ported head and fr32 cam. Using DD2 recorder ive managed approx 5.8secs on normal road in unscientific (read very!! just in case Chris M reads this!!! LOL) conditions. I bet id be lucky to have 120 - 130 bhp at the flywheel, maybe 95bhp at wheels on a good day.
Id like to think if i rebuilt engine to around 150 / 160 bhp at flywheel and stuck some R888 boots on id be around the 5sec mark. In anyones book that is fast for a little car, not many production cars up to £25K would stand a chance.
mookaloid
posted on 31/8/06 at 01:57 PM Reply With Quote
Originally posted by chris mason
Darren
i know that Darrens car once achieved a 0-60 time of 5.8 seconds, the strong gale and very steep hill helped tremendously though
i would expect a pinto with 150bhp to be somewhere in the 5's
fastest pinto i've seen is Mookaloids, i'm sure with bike carbs and a bit more fettling it should be even faster.
Chris
I've got my throttle bodies just working on an ECU etc
I reckon I'm around 4.5s on the 0-60 with a genuine 150BHP at the wheels and 3.92 diff + CR gearbox
Mark
DarrenW
posted on 1/9/06 at 02:15 PM Reply With Quote
Darren
Chris
he he he (you bugger!)
Dont set me of on that again, i did say it was unscientific. my launch technique is so dreadful that i need all the help i can get!
I can vouch for the speed of Marks car. I had a ride out in it and was amazed by how good it was. Well tuned, well set up, very torquy and amazing handling. Quite an achievement considering the ballast it was carrying at the time!!!!
captain carruthers
posted on 4/9/06 at 03:36 PM Reply With Quote
My 2.0 pinto does 0 -60 in about 5 1/2 secs no problem
its standard with a twin choke webber
it has 190 BHP per tonne
Jim
DarrenW
posted on 4/9/06 at 05:16 PM Reply With Quote
Jim
To put this into perspactive. I had a M3Evo a while back. They were a respectectable fast car. 321bhp as std, weighs 1430Kg and does 0-60 in 5.5secs according to the stats. That equates to around 225bhp/tonne.
The average Pinto 7 weighs around 580Kg. To get the same power to weight ratio you only need 130bhp at the flywheel which is quite easily achievable. There are not many 2.0 Pinto 7's that wont reach 0-60 in less than 6 secs. The problem is that you soon get used to the acceleration and start a quest for just a little bit more.................
billy
posted on 5/9/06 at 09:57 PM Reply With Quote
i would say rather a long time
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
captain carruthers
posted on 6/9/06 at 06:31 AM Reply With Quote
very true, thats the only problem ive propbably done about 700 miles in my Indy and already im looking for that bit more of that head on the back of your seat action!!!
hmmm bike carbs next i thinks!!
procomp
posted on 6/9/06 at 08:05 AM Reply With Quote
Hi IT also has a lot to do with the car setup irs -dedion - liveaxle - tyres and the individual persons clutch control. I have seen kitcars admitadly race ones but still using road clutches achive a 0-60 in 2.9secs and for the sprinters the 0-64 feet in 1.9secs all with road tyres and 200bhp in a car weighing 510kg.
cheers matt
NS Dev
posted on 7/9/06 at 11:34 AM Reply With Quote
Hmmm thats good to hear!!
Once I have sorted the crunch damage and sorted SVA I can report back on mine.
Should make around 175hp @ wheels (200 ish flywheel) and weight in the 550-600kg mark.
The VX 16v with alloy bellhousing etc should be a tad lighter than a pinto, not by much but every little helps!
