Jazzy
posted on 22/9/06 at 11:58 AM |
Zetec turbo in a Velocity
Hi, is it possible to install a Zetec turbo engine in a Velocity? Would the turbo be too close to the bodywork etc? Many thanks in advance.
ned
posted on 22/9/06 at 12:00 PM |
yes it would be possible. there have been vauxhall turbo's fitted to westfields and cosworth and nissan turbo's fitted to mk's which
are all near enough the same size body and chassis wise.
you may need some special parts to get the packaging right but it's definately doable.
Ned.
beware, I've got yellow skin
piddy
posted on 22/9/06 at 12:12 PM |
I saw a Velocity at Donny which seemed to have a Cosworth turbo fitted.
The owner had cut the chassis changed it and re welded it to get it all in.
Jazzy
posted on 22/9/06 at 12:15 PM |
Mmm sounds like too much work for me! If only it was a simple task.
Danozeman
posted on 22/9/06 at 12:35 PM |
It all depends how you make your manifolds etc. You can make them to fit..
Dan
big_wasa
posted on 22/9/06 at 02:56 PM |
Should do.
Pic of Westfield zetec turbo from PPc mag
graememk
posted on 22/9/06 at 04:54 PM |
an early pic of my mk build with a nissan turbo
graememkengine
ChrisW
posted on 13/10/06 at 02:29 AM |
From that pic it looks like the turbo outlet goes straight to the inlet manifold. Surely that's not the case - where is the intercooler?
Chris
richard thomas
posted on 21/10/06 at 08:44 PM |
Trust me, compared to the overall task of building the thing, a bit of chopping and changing is small fry. I had to cut the sh*t out of mine to fit
the bike engine, so long as you put some strength back in where you can it's fine. So long as you're not too far into the build, that
is...
Go for it !!!
Rich.
