Author: Subject: Springs
NeilP
posted on 9/10/06 at 06:10 PM Reply With Quote
Springs
The coilover springs I got from Luego were 300lb and 175lb respectively, which I was told were 300 for the rear and 175 for the front. As mi lump is heavier than the Rover V8, she is sagging a tad.
Question - Have I been a tit and put fronts on the rear and if not what do you think I should go to on the front, 250/275/300????
Thanks all - Imagine doing this all by yourself
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
posted on 9/10/06 at 06:35 PM Reply With Quote
Got 300lbs on the front and 150lbs on the rear of my Luego locost with cross flow lump . Think you might have them mixed up
NeilP
posted on 9/10/06 at 06:48 PM Reply With Quote
Better check the gearbox next!!!!
Chippy
posted on 9/10/06 at 10:46 PM Reply With Quote
Hi Neil, having fitted a 2.9i I can assure you that the spring should be 300lb front. 175 rear. Although I did find with mine that I had to go up to 350lb front, as the 300's were too soft. Regards Ray
zetec7
posted on 10/10/06 at 04:52 AM Reply With Quote
I'd agree - I've got 275's in the front (Zetec 2.0 engine) and 150s in the rear. Might be a tad soft in the rear end (hmmm...I knew a girl like that once), but the front seems nice and firm (come to thnk about it, I knew a girl like that, too!).
tks
posted on 10/10/06 at 03:35 PM Reply With Quote
mhhh
how are bec´s! doing it??
i have also noticed that the speed bumps in my village aren´t noticed by the front sptrings!
but i´m almost launched from my seat by the rears stiffness
its true that with the corsa you really notice these bumps..
have bec tough..
Tks
NeilP
posted on 10/10/06 at 06:05 PM Reply With Quote
No doubt risking mountainous abuse from Hellfire and his kin - Probably cos you've got two too many wheels on your Bike!
