Paul (Notts)
posted on 22/10/06 at 12:28 PM |
Viento rear hand brake cable
Can I use the standard sierra cable or do I need a shortend one?
Paul
StevieB
posted on 22/10/06 at 12:30 PM |
I'm having the same issues with my Indy build at the moment - you certainly need to shorten the cable, but I'm waiting to see if the cover
needs to be cut down as well
wilkingj
posted on 22/10/06 at 12:56 PM |
Viento definately needs a shorter cable. Bought mine from (old) Luego.
Also check the routing of the cable, as it makes a difference.
I have my calipers on upside down to get an easier (smoother) cable run.
So Bleed the calipers off the car, then invert and bolt on to the car.
Best Regards
Geoff
http://www.v8viento.co.uk
