saigonij
| posted on 23/2/07 at 09:58 AM |
Size and Dimension of Velocity and Viento
Hopefully someone can help me out here...
I want to know the sizes and dimensions of the velocity and viento engine bays.
Also, how much bigger is the viento to the velocity?
I basically want to know if a 2.5 duratec will fit in the bay of the velocity, or will i have to go to viento for that engine?
balidey
| posted on 23/2/07 at 10:29 AM |
Have you spoken to Luego, I think they may know.
Infact, I've just looked at Luego website and they list the Duratec as one of the engine option for the velocity.
saigonij
| posted on 23/2/07 at 12:43 PM |
not spoken to them yet.
the duratec they list is the in line 4 pot, not the 2.5 v6.
thanks for your reply...
bug1
| posted on 23/2/07 at 06:52 PM |
Hi if the duratec is close to the size of the 2.9v6 12 valve engine it should fit with little if any mods to the chassis thats what I have in mine
the only mod I had to do was to get the starter motor in and I had to shorten the plenum chamber to go under the nose you may also need to put a
small alternator on it will be very tight but theirs nothing like a full engine bay.
Paul (Notts)
| posted on 23/2/07 at 07:09 PM |
The Viento engine bay is BIG - makes a rover v8 look small
Steve Lovelock
| posted on 25/2/07 at 06:54 PM |
I bought an Alfa with a V6 engine for my Velocity and as soon as I started to measure it up I realised it would be very, and I mean very, difficult to
fit. I can't imagine that a Ford V6 is much smaller than an Alfa V6 so I'd recommend going for a four pot with the Velocity or a V6/8
with the Viento.
