dsapsfo1
| posted on 18/4/07 at 07:50 PM |
Viento throttle cable - V8 EFI
Evening all.
Can somebody please post a photo as to how they have run the throttle cable on an EFI Rover V8 - I assume the single and dual plenums have the
throttle cable running to the same point.
Many thanks...
dsapsfo1
| posted on 20/4/07 at 09:00 AM |
can anyone help? need some ideas please....
Dan
wilkingj
| posted on 20/4/07 at 11:38 AM |
It goes from the Throttle Pedal to the Carb or bit on the Plenum if injected. How and where you run it is up to you.
I would try to stop it drooping onto the exhaust pipes. It tends to melt the plastic.
  Engine Right1
Best Regards
Geoff
http://www.v8viento.co.uk
dsapsfo1
| posted on 20/4/07 at 12:18 PM |
Thanks Geoff - looks like you've been busy polishing under there!
I'm retrofitting an EFI RV8 in place of a carb'd one and the cable runs in a different direction. I know where it's running from
and to, just was looking for ideas as to how those with EFI lumps have routed the cable etc. Cheers
