Steve Lovelock
| posted on 24/5/07 at 04:54 AM |
Crack in rear fibreglass panel - Can I leave it?
I fitted the rear panel last night and when I was riveting the lower rear edge to the chassis I noticed that there is a little crack from one of the
wholes that I drilled to the corner and up the back panel about 3/4cm. The thing is what do I do about it? The panel is bonded and riveted in place
now so I am not taking it off. There is little scope for movement but I suspect enough scope for the crack to be put under pressure over time. From
above the crack is barely visible so I am not worried about the visual impact. Can I just forget about it?
speedyxjs
| posted on 24/5/07 at 06:16 AM |
Im not sure but if you fill it, the sva man might struggle to fiond any reason to fail on that.
fesycresy
| posted on 24/5/07 at 06:26 AM |
The only way to stock a crack is to drill a hole at the end of the crack.
Considering this sh*t this would cause I'd just leave it and keep an eye on it.
Lyn.
fesycresy
| posted on 24/5/07 at 06:27 AM |
I mean 'stop' a crack.
Spelling's not the best with a hangover.
RazMan
| posted on 24/5/07 at 07:08 AM |
I would drill a small hole in the end of the crack, grind a V into the rest of the crack with a Dremel and wipe some gel coat into it. You could also
use filler and touch it in with paint if it won't be too visible.
Raz
PeterW
| posted on 24/5/07 at 07:15 AM |
As said before...
Drill it, grind it and then fill it. If its bad, patch the back if you can.
Then put on any one of the chav Bilstein/Weber/etc stickers over the top !! Thats what we used to do on Mini's...!
Pete
Bluemoon
| posted on 24/5/07 at 07:33 AM |
I agree with fesycresy advice, you could put a small mark with a perminate pen so you know how far the crack has got.. If it moves drill a small hole
at the end.. If that fails to stop it then think about a proper fix..
Dan
Steve Lovelock
| posted on 24/5/07 at 12:22 PM |
Thank you, I can easily drill a hole at the end of it and grind a V into the crack without it showing as it is very small and at the bottom of the
panel.
richard thomas
| posted on 24/5/07 at 07:14 PM |
Just leave it. Honest.
