Paradoxia0
| posted on 27/5/07 at 02:37 PM |
Fuel tank breather pipe
Hi All
Very simple question (if you know the answer!). But where do I run the fuel tank breather pipe?
SHould thi point down to vent out of the bottom of the car (to act as an overflow too) or should it be strapped to the fuel filler pipe and run
upwards to above rthe filler neck?
Ta!
Mark
There is no replacement for displacement...
mangogrooveworkshop
| posted on 27/5/07 at 02:48 PM |
put a valve on it an run it high
Chippy
| posted on 27/5/07 at 02:55 PM |
If you can source a valve from the Sierra, and fit that in the breather pipe it will allow air in, but not fuel out. Fitted one to mine, (came with
the doner), works a treat, and my vent is fixed around the edge of the tank. HTH Ray
Paradoxia0
| posted on 27/5/07 at 03:15 PM |
Never thought about the valve...
Trip to my girlfriends mates to raid one of his Sierra's then
Any idea where I would find this valve to save me ripping half the back of the car to bits?
Mark
robertst
| posted on 27/5/07 at 10:59 PM |
Mark
so? does anyone know how to get one off a sierra?
i'm visiting the breakers soon and would like to know how to get at it...
Tom
Chippy
| posted on 27/5/07 at 11:12 PM |
Mine was bolted, (maybe self tap screwed), to the fuel filler pipe, between the filler cap and the tank. While your at it grab the pipes to. HTH Ray
