saigonij
| posted on 22/6/07 at 08:00 PM |
What Hose from fluid resevior to m/c
Hi All,
The hose from teh fluid reseviour to the master cylinders needs to be a specific type to pass sva. anyone know where i can get some from?
ian.
saigonij
| posted on 22/6/07 at 08:09 PM |
I should really use the search more!
wicket
| posted on 22/6/07 at 08:15 PM |
Mine are Fiat Seicento hoses.
A couple of pictures in my archive of marked hoses. The longer one is p/n 46774776, 290mm long, and the other is p/n 46774775, 220mm long. Total cost
£8.48 inc vat.
The reservoir is mounted on the driveres side foot well bulkhead.
If I had known I would have just bought 2 of the shorter ones, they are just the right length.
RazMan
| posted on 23/6/07 at 11:45 AM |
Cotton braided and designed for brake fluid - Your local hydraulic stockist will have some in stock.
Raz
JohnN
| posted on 23/6/07 at 11:57 AM |
Labelled brake fluid is the most important feature to Mr SVA.
Or at least a brand and code number, that you can then provide manufacturers literature to prove it is designed for brake fluid. Compared to fuel
hose, it's not easy to find
jollygreengiant
| posted on 27/6/07 at 01:14 AM |
£8.48 inc vat.
Must have been a run on these, none left in country, got to come from Italy.
Should have Friday
Should get Brakes at the weekend.
