saigonij
| posted on 2/7/07 at 09:49 PM |
rear calipers facing front or back?
which way should they face - front or back?
worX
| posted on 2/7/07 at 09:56 PM |
I found this in jollygreengiants photo archive, hope it helps!!!
  4 bolt rear hub, disc & caliper ass.
meany
| posted on 2/7/07 at 10:00 PM |
as calvinx says...
plus bleed nipples at the top.
Wadders
| posted on 2/7/07 at 10:01 PM |
Agree, it's not important, especially on the back as they do next to nothing anyway.
Al.
Originally posted by CaLviNx
Hi
A real world answer from me would be where ever you can fit them and get all your cable runs/clearances etc that suit your setup best.
JohnN
| posted on 2/7/07 at 10:12 PM |
Bleed nipples on my Luego rear hubs (sierra rear discs) are upside down - have to take caliper off to bleed it - not a real problem. Calipers are at
the rear of the hubs.
mark chandler
| posted on 2/7/07 at 10:15 PM |
Mine went on the back, nice straight run across the car for brake pipes, handbrake cable curls up and over towards diff.
Just had to remove, invert and gravity bleed when first installed.
Each to his own, it makes no difference in operation.
Regards Mark
Phil.J
| posted on 3/7/07 at 07:51 AM |
In an ideal car most of the weight should be contained within the wheelbase, so for the rear brakes fit them on the front of the discs. It has no
effect on the brake performance where you locate them.
saigonij
| posted on 3/7/07 at 07:53 AM |
well, i put the calipers facing the back of the car last night ( before i sent the post ) as i wanted the calipers to be at the back. However this
means that the brake lines goes behind the shock, and it would mean the hand brake cable has to go through alot of curves ,
so i think ill swap them over and have the calipers at the front.
RazMan
| posted on 3/7/07 at 08:24 AM |
I mounted mine to the front due to my handbrake cables routing. The nipples ended up on the bottom so I have to remove them when bleeding but its not
a problem to do that.
Raz
