Amazing Offer
Hi, if you have a look at the comprehensive price lists, then reduce the total cost by £420.
The show offer is below:
Deluxe Luego-Locost Live Axle Show Starter Kit
With Free Powder Coated Chassis & Wishbones Normally £195
Fully Bracketed Chassis, 8 piece GRP, Aluminium Internal and External Panels Pre-folded with Holes, Wishbone Set, Polly Bush Set, Road Roll Bar, 4
Point Harness Bar, 4 Trailing Arms, Panard Rod, Powder Coat, Mild Steel Road Fuel Tank, Escort MK II Steering Rack, Gold Pedal Box, Engine Mounts and
Rubbers, Wiring Loom, Fuel Tank Breather Non Return Valve, Steering Column Fitting Kit, Aluminium Tax Disc Holder, Bonnet Clips x 4, 6mm Brake Pipe,
Cable Ties, 3 Way Brake Union, 4 Way Brake Union, Brake Light Switch, Side Mirrors, Rubber Mounted SVA Indicators x 2, Side Repeaters x 2, Harness
Eyes x 8, 4 Point Harness x 2, Stone Guards x 2, Luego Nose Badge, Hand Brake Cover & Gaiter, Gear Knob & Gaiter, SVA Bolt Caps x 20, .
Normally £3,149
Summer Show Price Only £2,800 Inc VAT
Deluxe Luego-Velocity I.R.S Show Starter Kit
Fully Bracketed Chassis, 8 piece GRP, Aluminium Internal and External Panels Pre-folded with Holes, Wishbone Set and Rear Hub Carriers, Polly Bush
Set, Aluminium Conversion Boss x 2, Road Roll Bar, 4 Point Harness Bar, Powder Coat, Aluminium Road Fuel Tank, Escort MK II Steering Rack, Gold Pedal
Box, Engine Mounts and Rubbers, Wiring Loom, Fuel Tank Breather Non Return Valve, Steering Column Fitting Kit, Aluminium Tax Disc Holder, Bonnet Clips
x 4, 6mm Brake Pipe, Cable Ties, 3 Way Brake Union, 4 Way Brake Union, Brake Light Switch, Side Mirrors, Rubber Mounted SVA Indicators x 2, Side
Repeaters x 2, Harness Eyes x 8, 4 Point Harness x 2, Stone Guards x 2, Luego Nose Badge, Hand Brake Cover & Gaiter, Gear Knob & Gaiter, SVA
Bolt Caps x 20.
Normally £3,513
Summer Show Price Only £3,170 Inc VAT
Deluxe Luego V8 Viento Show Starter Kit
Fully Bracketed Chassis, 8 piece GRP, Aluminium Internal and External Panels Pre-folded with Holes , Wishbone Set and Rear Hub Carriers, Polly Bush
Set, Road Roll Bar, Aluminium Conversion Boss x 2, 4 Point Harness Bar, Powder Coat, Aluminium Road Fuel Tank, Escort MK II Steering Rack, Rack
Extensions, Gold Pedal Box Hydraulic Clutch, V8 Engine Mounts and Rubbers, Wiring Loom, Fuel Tank Breather Non Return Valve, Steering Column Fitting
Kit, Aluminium Tax Disc Holder, Bonnet Clips x 4, 6mm Brake Pipe, Cable Ties, 3 Way Brake Union, 4 Way Brake Union, Brake Light Switch, Side Mirrors,
Rubber Mounted SVA Indicators x 2, Side Repeaters x 2, Harness Eyes x 8, 4 Point Harness x 2, Stone Guards x 2, Luego Nose Badge, Hand Brake Cover
& Gaiter, Gear Knob & Gaiter, SVA Bolt Caps x 20.
Normally £4,329
Summer Show Price Only £3,990 Inc VAT
