ChrisW
| posted on 8/9/03 at 07:41 PM |
Gearbox mount - what to use?
What mounts have you lot all used for your gearboxes? I'm using a type 9 box which obviously needs a rubber mount of some description between
it and the mounting plate. Any suggestions or should I give Grant a call?
Chris
My gaff my rules
bob
| posted on 8/9/03 at 09:05 PM |
CHRIS
What about the one that usualy goes on a type 9,i drilled mine out of the original VERY large housing and bolted it straight in.
ChrisW
| posted on 8/9/03 at 09:49 PM |
I'll investigate but I was thinking of something a bit smaller!
The Luego chassis already has the plate there for the gearbox to sit on whereas I thought the Indy used the Sierra gearbox mount complete with the
steel cross member bit?
Chris
My gaff my rules
tobygee
| posted on 8/9/03 at 09:54 PM |
i used the mounting off of the gearbox type 9 and once i knew where i wanted it cut out the inside shape of the plate (whith rubber on it) and mounted
on top of chassis plate!!
tobygee
| posted on 8/9/03 at 09:57 PM |
IE cut that shape out of the chassis plate and put the rubber mount with plate in/on it, drill the holes and bolt it!!
Northy
| posted on 9/9/03 at 06:53 AM |
I've found the original Sierra mount a bit on the soft side
Graham
bob
| posted on 9/9/03 at 07:37 AM |
You can get a stiffer mount from westfield for the type 9 for about 12 quid.
Chris
the sierra mount will fit yours,just a case of drilling out the centre plate.
I think you'll find a pic on my archive,if not pop round and have a look.
ChrisW
| posted on 12/9/03 at 10:11 PM |
Couldn't see how it comes apart on the one I've got but maybe it's different. Needs to be about 10mm thick as I'm pushed for
space in there already.
Chris
My gaff my rules
James
| posted on 15/9/03 at 01:06 PM |
quote: Originally posted by ChrisW
<snip>
as I'm pushed for space in there already.
Chris
Yeah, I can see how space would be a problem in a Viento!
James
ChrisW
| posted on 16/9/03 at 11:47 AM |
It's perhaps too much space that's the problem. My engine is too short to clear the bulkhead :s
Anyway, I picked up an unknown rubber mount at Donny show which I'm hoping will do the trick.
Chris
My gaff my rules
