Author: Subject: Been Making a Radiator mounting plate
jollygreengiant
posted on 9/11/07 at 07:17 PM Reply With Quote
As per the title really, all comments welcome. I will be installing a cooling fan on the front blowing through. Just got to organise the coolant pipes now.
This is from the back and above.
Rad mounting plate from back/top
This is from back and below.
Rad mounting plate from bacl/bottom
And this is mounted on the car.
Rad & mounting plate on car
And yes that is the utility room sink in the background of the first 2 photos. And yes the first on is a little fuzzie.
Enjoy.
blakep82
posted on 9/11/07 at 07:22 PM Reply With Quote
proper job that is!
________________________
richard thomas
posted on 9/11/07 at 07:23 PM Reply With Quote
V nice!
NeilP
posted on 9/11/07 at 07:27 PM Reply With Quote
Nice work, Clive - The end must surely be in sight?...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
richard thomas
posted on 9/11/07 at 07:32 PM Reply With Quote
Clive, I read somewhere that you should try to use some rubber washers in there somewhere to insulate the rad from vibration - they don't like it apparently...
Mind you, I never used any....but thought I should pass on the info
jollygreengiant
posted on 9/11/07 at 07:47 PM Reply With Quote
Yep already thought of that. The Alloy sheet is fairly thin and flexible but the bulk of the radiator weight is/will be taken on the bottom rail and the radiator its self is mounted by its lower mounting pins onto this bottom rail through rubber grommets. IF the whole assembly (alloy sheet) proves too thin then I can use it as a template on heavier gauge if necessary.
Thanks for the thought anyway Richard.
big_wasa
posted on 9/11/07 at 09:15 PM Reply With Quote
Nice
Confused but excited.
posted on 10/11/07 at 05:35 PM Reply With Quote
Very nice job.
jollygreengiant
posted on 11/11/07 at 11:58 AM Reply With Quote
Thanks lads. After seeing Ricky's Rad I'm going to sulk now. So its off to do a bit of shopping then when I get back I'm going to try and make an impressive battery tray to sit down in the bottom of the nearside engine bay between the engine mounting and the front bulk head.
Oh and I'm trying to move wheres Luego down the listings.
repper
posted on 11/11/07 at 05:34 PM Reply With Quote
that looks well smart mate
whots the rad is it a polo one
jollygreengiant
posted on 11/11/07 at 06:08 PM Reply With Quote
Yes it a polo rad from Northern Radiators. Literally next day delivery. Ordered at 4:30. Deliivered 11 next morning.
