Paul (Notts)
posted on 30/12/07 at 01:19 PM |
Luego brake balance bar set up.
Two years ago I had two locking nuts that I carefully drilled out ready to fit a roll pin in to lock the balance bar.—I have put these in a very safe
place and now cant find them!!!!!
Any body know what thread size the balance bar is on the luego assembly?
It looks close to m12 but a finer thread..
Paul
Howlor
posted on 30/12/07 at 01:37 PM |
7/16th? IIRC
Paul (Notts)
posted on 30/12/07 at 01:38 PM |
Cheers..
thats what I as just thinking myself..
Paul
tks
posted on 30/12/07 at 02:59 PM |
Our own balance bar using a 7/16 UNF threaded shaft.
look at raldes think thats the one my luego uses...
Tks
tks
posted on 30/12/07 at 03:02 PM |
How can you undo the bias bar / brake pedal if you dont want to undo the master cilinders??
You would think that turning it to one side should just work but for me it doesn't (the other pushthinky presses against the centre ball..
Tks
richard thomas
posted on 30/12/07 at 04:59 PM |
Tks
If I understand that correctly, you have the two pushthinkies too tight to the centre tube...
I am still not sure which master cylinder pushrod the centre ball should be wound closest to in order to favour that cylinder for more bias - can
anyone enlighten me?
hector
posted on 30/12/07 at 06:33 PM |
Hi they are 7/16 unf
Optimum Balance Products
posted on 2/1/08 at 11:52 PM |
Hi, they are 7/16 unf.
Have a look at this link may help.
http://www.obp.uk.net/pedal%20box/Pedal%20Box.htm
If you email me at sales@obp.uk.net i have a help sheet on the bias bar set up.
All the best,
Grant.
Optimum Balance Products Ltd specialise in floor mounted and top mounted pedal boxes. We also manufacture many other products and can under take one
off alloy fuel tanks or other design projects. Please contact us via email to sales@obpltd.com or have a look at our fantastic ecommerce web site
www.obpltd.com
Thank you for your time.
All the best,
Obp Ltd.
