GregMcN
posted on 25/3/08 at 08:04 PM |
Noise level?
Has anyone measured noise levels from R1 with standard MNR s.steel silencer. + foam filter (no airbox) Just wondered whether I was likely to have
problems if I tried a trackday - it seems pretty loud.
Thanks Greg
smart51
posted on 25/3/08 at 08:54 PM |
Mine measured 108 dB. Not that yours will be the same necessarily. Marc reckoned at the time that the meter was probably a bit out as with his
calibrated meter they were usually quieter.
Remember that intake roar makes up a good proportion of the sound if you have a foam filter.
amalyos
posted on 25/3/08 at 09:07 PM |
Mine measures 104db with a 30" MNR silencer and a homemade airbox.
Measured at 7500rpm.
http://stevembuild.blogspot.com
TimC
posted on 25/3/08 at 09:56 PM |
Bugger - even though my MNR can is longer than most that's a worry!
Does anyone have experience of the Pipercross airboxes? i.e. this thing.
[Edited on 25/3/08 by TimC]
marc n
posted on 25/3/08 at 11:26 PM |
hi all most of the time people have noise problems after their car has been svad as when the cat is added the heat buildup is so bad the insulation /
packing goes hard and disintegarates, try repacking first, i run a shorter silencer than most of you have and i dont have any problems even before i
fitted the airbox
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
marc n
posted on 25/3/08 at 11:28 PM |
we have just started stocking the pipercross airbox , very good for the money
cheers
marc
chunkytfg
If the Cars are anyting like the Bikes i have to get noise tested for trackdays then mechanical noise is a huge factor aswell.
Make sure the engine is well up to temp as for a bike that can be worth 1db and make sure your engine bay is either insulated or you strtegically
place people to act as sound deadening from the meter to the engine
Davey D
posted on 26/3/08 at 12:17 PM |
Ooooh im liking that airbox.... How much are they Marc? ![](/images//smilies/bigsmile.gif)
Guinness
posted on 26/3/08 at 12:54 PM |
Damn you Marc! I've just bought one from Demon Thieves! Arrggh!
Nevermind.
I have a Db meter and will do some back to back testing when / if it arrives!
Mike
marc n
posted on 26/3/08 at 03:34 PM |
£175 inclusive ![](/images//smilies/smile.gif)
cheers
marc
stuart_g
posted on 26/3/08 at 09:59 PM |
Can they be fitted to a 5VY R1? as the servo motor and fuel rail are raised above the top of the throttle bodies.
marc n
posted on 26/3/08 at 10:31 PM |
hi stuart i dont know to be honest fitted one to a 5pw the other day but not tryed on anything newer
cheers
marc
bobs bangers
posted on 27/3/08 at 12:01 AM |
how about a zx10r ? rt inboard.
Also now thinking of supercharging!!
Regards
Bob
GregMcN
posted on 28/3/08 at 12:35 PM |
air box
Marc
Does the air box use the foam filter or something else?
Greg
TimC
posted on 28/3/08 at 04:08 PM |
One more question Marc - does it use the standard base plate for the ususal Pipercross filter?
Cheers.
marc n
posted on 28/3/08 at 04:45 PM |
no different baseplate we cut those here
uses a separate foam cone filter
dont know not tried one on a zx10 had them on fireblade and r1 upto and including 03
cheers
marc
Guinness
posted on 28/3/08 at 11:13 PM |
Well my PX600 Series Airbox arrived from Demon Thieves on Wednesday afternoon. I just un-clipped the existing sausage using the 3 x dzus fasteners,
then stuck the airbox straight on. It came ready fitted with an inverted cone filter, a can of dirt retention spray and a couple of feet of flexy
duct.
Took all of 5 minutes to fit, straight to the existing base plate.
Will post up some info on noise levels after tomorrows testing.
HTH
Mike
TimC
posted on 29/3/08 at 07:07 AM |
That's what I thought - now confused. You say Yes; Marc says No.
marc n
posted on 29/3/08 at 07:34 AM |
i must be using a bigger size one or mikes original airfilter is diffferent to what we use normally ? as the baseplate for the airboxes i have fitted
is a lot bigger than the sausage type
cheers
marc
road warrior
posted on 29/3/08 at 10:18 AM |
Stuart
I had to make a base plate from fiberglass and move a few things to suit the 5VY. It isn't too difficult and doesn't take very long to
do. Greg still has your email address so I will send you an email with pics and how to do it tomorrow night. I can't find the pics right now and
am just about to load the car in the trailer for a supersprint tomorrow.
Sonja
Davey D
posted on 29/3/08 at 12:16 PM |
quote: Originally posted by road warrior
Stuart
Sonja
Could you post me some piccies too, as ive been wondering what people with 5VY have been doing for their air filter
road warrior
posted on 29/3/08 at 12:57 PM |
No problem, send me your email address and I will send a copy.
Sonja
