saigonij
| posted on 11/5/08 at 07:20 PM |
Progress - Dashboard
I have started to make my dash board this weekend.
I started with a cardboard template and then transfered it to a sheet of plywood.
  dashboard1
I then drilled holes ( wonky ones ) for the bright 6.
  bright6
With a bit of fettling, i then bolted it to the schuttle.
  dashboard_from_front
Im still to figure out how to do the 19mm radius along the bottom...
any ideas?
SeaBass
| posted on 11/5/08 at 07:21 PM |
The SVA inspector might not like the size of those gauges. I can hardly read them myself - just image what they'll be like at speed.
JC
big_wasa
| posted on 11/5/08 at 07:22 PM |
gear stick looks a good length
saigonij
| posted on 11/5/08 at 07:23 PM |
saigonij
| posted on 11/5/08 at 07:25 PM |
Big_wasa
Yea, the gear stick is spot on thanks...
one question, the hole in the end of the lever, that fits of the stub ( with a role pin ) is a little loose - what can i do to make it less loose?
roadrunner
| posted on 11/5/08 at 07:27 PM |
Glue and pin some 20mm quadrant to the bottom edge then cover with vinyl.
locoboy
| posted on 11/5/08 at 07:30 PM |
For the radius i used a length of domestic waste water pipe -the white stuff, cut along its length and covered with a suitable material such as vinyl
then i just opened up the split at one end and slid it onto my dash.
Easy peasy.
Oh my dash was 6mm MDF.
Just found a piccy of what i mean
  dash and paddles
  dash rad tube
[Edited on 11/5/08 by locoboy]
Locoboy
big_wasa
| posted on 11/5/08 at 07:31 PM |
either use a bigger roll pin or I have used an M6 counter sunk screw
saigonij
| posted on 11/5/08 at 07:34 PM |
do you have any pictures?
| posted on 11/5/08 at 08:13 PM |
If its a type 9 box the plastic "saddle" is probably worn , about £1 from Ford.
| posted on 11/5/08 at 08:25 PM |
I used some lagging pipe slit and covered in vinyl. I've taken it off now but it passed SVA and looked reasonable (in fact I think I left it on
for quite a few months!!)....
indykid
| posted on 11/5/08 at 08:34 PM |
i stuck 3 bits of 6mm mdf together and rounded it over with a half inch router bit.
bit more sanding then vinyl stuck on top.
tom
Chippy
| posted on 11/5/08 at 10:35 PM |
The roll pin problem of it being a bit slack, I had it as well with my MT75. Take the pin out and spread it a bit, I used a pin punch that was just a
bit bigger than the hole in the pin, bugger to get it out again, but the pin went in nice and tight. HTH Ray
