ahb
posted on 12/5/08 at 09:33 AM |
Indy prop
Hi, help required please, fitting prop to my zx9 indy. Do you need to put a spacer on the middle joint. Mines is very close to the chassis. If so what
do you use? Cheers
mike smith1
posted on 12/5/08 at 09:40 AM |
Yes you do need to space it off, i cannot remember by how much but the spacers were made from some tube with a heavy wall thickness.
Mike
ahb
posted on 12/5/08 at 09:48 AM |
Thanks for that. Better to check first. Off to find some spacers now!!!!
Kriss
posted on 12/5/08 at 10:14 AM |
when I last looked at mine mid build at BEC Center, it looked like mine had about 8 - 10 spacer washers pushing the prop away from the drivers
firewall/feet.
macspeedy
posted on 12/5/08 at 10:55 AM |
i think this is from hellfires website, i was looking at fabricating a bar between top and bottom tunnel rail, in a "C" shape
[Edited on 12/5/08 by macspeedy]
![](/galpreviews/a741879-prop.jpg) ![Rescued attachment prop.jpg](/gallery/a741879-prop.jpg) Rescued attachment prop.jpg
macspeedy
posted on 12/5/08 at 10:59 AM |
another angle
![](/galpreviews/a741881-P1011068.jpg) ![Rescued attachment P1011068.jpg](/gallery/a741881-P1011068.jpg) Rescued attachment P1011068.jpg
ahb
posted on 12/5/08 at 11:25 AM |
Just been out and got some spacers. They should take it out by 10mm. I'll give them a try and let you know.
Al.
ahb
posted on 12/5/08 at 11:41 AM |
Does the rear section of the prop need to be exactly in the centre of the tunnel?
matt.c
posted on 12/5/08 at 12:31 PM |
make sure you use long enough bolts as well so the thread goes into the thread lock on the nut.
eddbaz
posted on 12/5/08 at 02:47 PM |
I've got the same problem with my prop, i'm going to make some spacers as mentioned,macspeedy on your photo are your bolts tight because
as mentioned above the locking nylon hasn't got any thread in it,I think I would want at least a couple of turns showing in such a critical
area.
posted on 12/5/08 at 06:08 PM |
Ed,
the photos are of our Indy and the bolts were loose in the lower picture.
Phil
