Author: Subject: Blacktop Zetec camblet change
Mark G
posted on 27/5/08 at 06:59 PM Reply With Quote
I have to do a cambelt change on my tintop soon, It has a 2.0 16v Blacktop Zetec engine. Do I have to take the rocker cover off to time it up or will I get away with just marking the cam pullies and changing the belt.
Many thanks
Mark.
big_wasa
posted on 27/5/08 at 07:30 PM Reply With Quote
on the silver top you need to take the cover of to line the cams up with a 5mm plate.
Not doing this will give you a good chance of being a tooth out.
I think the Blacktop is the same for this.
[Edited on 27/5/08 by big_wasa]
mr henderson
Have you had a look at the haynes manual for the zetec? Reason I ask, is I wouldn't fancy doing the job without one
John
Mark G
posted on 27/5/08 at 07:51 PM Reply With Quote
I don't have a manual for the Zetec, no. I don't really intend on buying one either. I'm a techie by trade but I've never really had any involvement with fords before.
I did a head gasket on my old silvertop and lined that up with the cover off as it was no extra work. I was hoping I could do this one without having to take the top off. But I'm just being lazy.
Reason I ask is because I'd like to know if I'll need to order a new seal for the rocker cover. Think I'll just get one to be on the safe side.
the_fbi
posted on 27/5/08 at 10:26 PM Reply With Quote
ideally you should use the 5mm plate to lock the cams and the "spike" to lock the crank into position. (there's a hole on the front of the block where you screw the spike into).
No idea where it was used, but the garage which did mine also had a weird L shaped spanner with the equivalent of a castellated nut (without the threads) on the end which they left under the bonnet.
For £10 of tools and whatever the camcover gasket costs, I wouldn't risk the job not being done right.
Schrodinger
posted on 28/5/08 at 01:43 PM Reply With Quote
Having done my silvertop a while back, when you take the belt off if the engine is at tdc the cams will move as some of the valves are begining to open and will snap closed as soon as the tension in the belt has gone. I would take the top off and do it with the correct tools.
Keith
Aviemore
posted on 28/5/08 at 07:42 PM Reply With Quote
You will need the correct tool to undo and tighten the cam pulley bolts or need to make one. DO NOT use the cam timing bar to lock the cams while undoing the pulley bolts .
mark-wiring
posted on 2/6/08 at 04:36 PM Reply With Quote
I do hope thats not from 1st hand knowledge of what happens.
You will need the correct tools for doing the job my mate found out the hard way tried to do it by marking the pullys and saving on a rocker gasket ended up costing him 16 valves and guides!!
And he only had to ask to borrow the tools!!!
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
posted on 2/6/08 at 06:57 PM Reply With Quote
As if?? But I have seen it done by someone that wouldn't listen . Made my day.
mark-wiring
posted on 2/6/08 at 08:07 PM Reply With Quote
LOL well that was there fault it dont pay to cut corners
Have to recommend
Mark G
posted on 3/6/08 at 09:59 PM Reply With Quote
Cheers all, I'll take the top off.
