jollygreengiant
posted on 30/7/08 at 08:11 PM |
New bits arrived today
Well I received the new bits I had been waiting for today.
Anyone want to guess where they fit.
My new bits
Those who might already know should not post.
Oh and thanks Dave they will be perfect.
Edit bit - if you want to copy the design ask but if some one starts mass producing them then I hold all rights of general design &
manufature.
[Edited on 30/7/08 by jollygreengiant]
posted on 30/7/08 at 08:15 PM |
Do they need batteries??
thunderace
posted on 30/7/08 at 08:26 PM |
indicator and light stalks
nib1980
posted on 30/7/08 at 08:28 PM |
throttle feed for the jet engine?
chris_smith
posted on 30/7/08 at 08:33 PM |
indicator extensions??
COREdevelopments
posted on 30/7/08 at 08:34 PM |
stunt pegs for your rally burner?
Mr G
posted on 30/7/08 at 08:35 PM |
bmx stunt pegs
r1_pete
Handles for the pillion on Chris' avatar.....
jollygreengiant
posted on 30/7/08 at 08:37 PM |
Ok so they go on these
Go on these
Like this
Like this
and will go into my indicator extension bar ( doubles as a bumper bar) to be clamped in by some grub screws from behind
into indicator bar
Dangle_kt
posted on 30/7/08 at 08:44 PM |
will that mean you don't need to have mr SVA dreaded globe rattling round the front suspension?
eznfrank
posted on 30/7/08 at 08:54 PM |
or Handles for the pillion on CoreDevelopments avatar!!!
jollygreengiant
posted on 30/7/08 at 10:18 PM |
Hopefully that is the general idea. But you know the testers usually have other ideas.
posted on 31/7/08 at 08:12 AM |
hope you are using one tube for the bar or have fairly hefty mounts - the legnth means they will wobble quite a bit.
jollygreengiant
posted on 31/7/08 at 09:29 AM |
Yep approx 1inch steel tube in one piece across the top of the nose. It will be bolted either side of centre (bolts to also hold grille in) through
rubber grommets in nose cone sides and just inside of nose the bar will have electrical condiut exit routes each side that will assist the bar in
deforming 'should' anything make hard enough contact so that damage to the nose would be minimalised.
posted on 31/7/08 at 08:07 PM |
I thought they might have been larger jets for the "pink barbie"
