richwill
| posted on 1/10/08 at 09:28 AM |
steering bush
How do i stop the steering column bush from working loose from the rubber grommet in the bulkhead. I have only driven the car a few times from my
garage and up the lane but everytime i do the steering column bush works loose. Advice please.
Mr Whippy
| posted on 1/10/08 at 09:30 AM |
epoxy glue? try coating the inside of the bush in a light coat of grease
[Edited on 1/10/08 by Mr Whippy]
jabbahutt
| posted on 1/10/08 at 09:52 AM |
ooh ooh, I might actually know this. Shouldn't there be a large round metal dic with a triangular hole in it that holds the assembly
together.
I had the same problem and it was the fact I hadn't tapped it down the column.
see my photo archve named bush retainer(sorry didn't have time to resize)
Nigel
Mr Whippy
| posted on 1/10/08 at 09:55 AM |
a what?
Paul TigerB6
| posted on 1/10/08 at 09:58 AM |
a what?
Oooooopppppsssss!!!!!!
jabbahutt
| posted on 1/10/08 at 10:07 AM |
right, another thing to add to my list of inabilities, car steering, car electrics, I.T and typing
try again large metal disc
Why is it people always notice the really bad typo errors?
| posted on 1/10/08 at 10:26 AM |
I pushed the bush fully home, drilled a small hole through the triangular tube and put a split pin through.
Ford used a push on fix washer that on mine was loose and next to useless
Mr Whippy
| posted on 1/10/08 at 10:33 AM |
yeah as glue and Bush don't mix
oh groan
Fub
| posted on 1/10/08 at 10:37 AM |
steering bush
I have used a jubilee clip as my first idea was to drill a hole & put a screw in, that worked fine but I had to move the column & so lost the
hole.
Jubilee will act like the spring clip & it doesn't catch anything.
I have put a secondary bush on as I use the steering wheel as a lever to get out.
The second one is in the engine bay, supplied by robin hood so no matter what I will have a bush giving the support needed
richwill
| posted on 1/10/08 at 10:49 AM |
Thanks guys i had tried to stop it moving with silicone sealant but failed miserably. I think i'll try a jubilee clip and see how that goes.
| posted on 1/10/08 at 11:07 AM |
Jubilee clips is traditional. Works fine (IME).
Dusty
| posted on 1/10/08 at 11:18 AM |
You can use a self aligning bearing like the one illustrated on the NWRhocar site
here. I have one fitted, nice solution but ? slight overkill perhaps.
