Cubby
posted on 28/10/08 at 04:16 PM |
Flywheel fitting
Hi ,
Can anyone confirm for that the flywheel on a Balcktop Zetec can only be fitted in one position relative to the crankshaft holes . The engine ran fine
before I took it off to replace the rear oil seal but now it won't start and appears like the igniton timing is way off and firing at the wrong
time . Impressive quantites of flame from throotle bodies and exhaust but won't start . Could I have it fitted 180 degrees out for example ?
Engine is running on Alpha full injection .
Quite depressed so giving up for today !
Danozeman
| posted on 28/10/08 at 04:30 PM |
The silver top zetecs can only be fitted one way as the holes are spaced different so im sure the black tops will be the same.
Dan
snapper
| posted on 28/10/08 at 06:49 PM |
Your Crank position sensor reads of the flywheel so i suspect there the problem lays.
On the Megajolt the sensor is 90 degrees to the missing tooth when the engine is at TDC
I eat to survive
I drink to forget
| posted on 28/10/08 at 06:56 PM |
Might be worth taking the crank sensor out and turning the engine over while probing for the missing hole in the flywheel , you should be able to work
out crank position from the marks on the pulley??. I would have thought it possible to fit the flywheel in one position only.
snapper
| posted on 28/10/08 at 07:04 PM |
After consulting with my Girls boyfriend, he asked whether you could have moved the crank prior to re fitting the flywheel, shouldn't make any
difference unless it has caused some ECU confusion
I eat to survive
I drink to forget
Dusty
| posted on 28/10/08 at 07:11 PM |
Only fits in one position so not possible to mess it up. Blacktop or silvertop are the same and the flywheels are interchangeable.
[Edited on 28/10/08 by Dusty]
Cubby
| posted on 28/10/08 at 08:01 PM |
Thanks just had that nasty feeling as normally I mark them prior to taking them off but due to my excitement I pulled it off just momentarily before
my brain kicked in and it was then too late.
I'll pull out the crank sensor tomorrow to double check . Any one know where the sensor is (degrees) to the missing tooth when the engine is at
TDC
