End of season......
major - 1/9/12 at 05:22 AM
So this is the end of the driving season for me...
I thought the ground clearance was enough, but the I met this.....
road
road
and as a result:
box
box
out
out
up site
up site
empty
empty
stevegough - 1/9/12 at 06:10 AM
Holy Crap! That's not done it a lot of good!
What is it? a railway line or something?
major - 1/9/12 at 06:22 AM
Nope, it is a point where an old bridge meets the road...
I only drove 15MPH entering a T crossing...
Imagine what would happened if I drove 45 mph....
clairetoo - 1/9/12 at 06:32 AM
That really sucks
stevegough - 1/9/12 at 06:43 AM
Originally posted by clairetoo
That really sucks
Clare - weld it back up for him??
renetom - 1/9/12 at 06:50 AM
major - 1/9/12 at 06:57 AM
Only a small bit to weld....
Gearbox is shot...
Adapter plate is also shot..
Current balance:
New custom driveshaft,
New engine mounts,
New engine and gearbox rubbers,
Adapter plate,
New hydraulic clutch system.
New custom gear lever system,
Several small bits an pieces.
No damage to the
- flywheel
- clutch itself..
- engine crankshaft as far as we can measure.
- sump.
renetom - 1/9/12 at 07:04 AM
Hi
Sorry to see this
hope you can get it back on the road soon.
A suggestion , fit a pair of steel skids under the sump & box.
We did this on our Indy R1 & it works a treat,(experience) no need for any welding
all bolt on, may add a little weight but definitely worth it, you'l only loose about 8mm in height.
Good luck
René
major - 1/9/12 at 07:14 AM
Originally posted by renetom
Hi
Sorry to see this
Good luck
René
We are looking to get a bit more hight by mounting the engine slightly higher and mounting skids underneath.
Fact remains the road clearance of a Duratec and a MT75 solution is c**p.
myke pocock - 1/9/12 at 07:24 AM
FIFTEEN MPH, GOOD GOD!!! And I thought a broken sump on my x flow was bad enough!!!
Daddylonglegs - 1/9/12 at 07:34 AM
I hope you're going to claim for that!?
jollygreengiant - 1/9/12 at 07:47 AM
That is bad. Sorry to hear of your troubles. Just out of curiosity, where exactly did it happen and I trust that you are going to try and get compensation from the relavant authority.
major - 1/9/12 at 07:57 AM
Filed a claim with the local authorities.
It was on a sunny saturday afternoon and no witness were present.
However the damage was pretty bad and I needed a special tow-truck
to remove the car from the location, which might help the claim.
[Edited on 1/9/12 by major]
stevegough - 1/9/12 at 08:07 AM
It doesn't actually look that high on the photo, although it does cast a bit of a shadow and there isn't much evidence in the photo to show scale - how much ground clearance did you have with your car?
NeilP - 1/9/12 at 08:29 AM
All the utilities face fairly steep fines from the LAs if their reinstatement after roadworks is outside +/- 10mm of the original road height IIRC. They are ruthless is getting these fines in so a bit of 'loyering up' might be in order to reverse the cards...
Made a real mess - hope the damage list stays as it is.
Beautiful build by the way - trying to persuade my made to bin the zetec in his Westy and go Duratec.
N.
major - 1/9/12 at 08:41 AM
That's the problem, I have a clearance of approx 8cm.
The bridge however is curved and the highest point is the place where the
steel rim is protruding for about 3 cm. Between the 1st and the 2nd steel rim
there is a hole which is about 5 cm deep.
You don't notice the bend in the bridge when you are driving. If you look from the side
of the road, you see the bend better.
First letter is send, and I am waiting for a response.
At present no car, I feel kind of lost without it......
I do have an other fast car but it is not the same......
RK - 1/9/12 at 12:33 PM
I did the same thing, with a story I won't go into. My season was over in March. Good luck with your repairs!
major - 15/9/12 at 10:58 AM
Got a phone that all bits and pieces were in.
The MT75 was preped last week and the new driveshaft could also be collected.
Perhaps,,,, I might be able to drive this year after all!!!
PS:
Decided to go for a front windshield.
