Engine Now Out And Gone Off To Andy B For Dynojetting,Ultrasonic Clean Up,Carb Balancing,New Clutch Plates And Uprated Springs,Strip And Re-Build And
Hopefully A Clean Bill Of Health Accompanied With A Certificate So I Can Register It On A Brandnew 09
Plate
which engine are you using? R1?
sounds expensive anyway! How come you didnt do it before the engine was fitted?
1995 893cc Blade 18000 Miles??
Brought Without Hearing It Run,Just Turned It Over To See If It Had Compression.Curiosity Got The Better Of Me And I Wanted To Hear It Run/Drive It
Kids And New Toys
Is the fuel filter OK mounted on the glass bulkhead?
Kids And New Toys
