bit of fun but its good.
This calculator has been based on sample data and statistical averages to estimate approximate 1/4 mile and 0-60mph times. Please be sure to enter
engine (flywheel) brake horsepower and the kerb weight (ie car empty, but with driver). The figures are based on front wheel drive and manual
transmission. If your VW is RWD or 4WD, you can expect times a little better than the calculator gives (but the extra transmission components
increases weight).
http://www.fastgolf.org.uk/modules.php?name=Calculator
Thats pretty accurate. I put the power and weight of my Jag in and the times were pretty much spot on even though its rwd
Also says my locost will do 0-60 in about 4 secs and 1/4 mile 12.5
3500 HP AND A KERB WEIGHT OF 1 KG WILL GIVE YOU 60 I 0 AND THE QUARTER IN .4
can you tell im bored
