Whats the difference between a rush and a locost!
Chassis design, cost, size, donor axle etc. used.
That enough for you?
the general difference is that rush's are made by dax, locosts are made by anyone.
"Chassis design, cost, size, donor axle etc. used. "
and the other one is a dax
Originally posted by JoelP
locosts are made by anyone.![]()
speed (rush - geddit?)
the Dax is a development of a theme, proffessionaly welded etc produced on a jig all component to .00001 of a millimetre etc,. Slightly bigger and
heavier than a Locost .
Locost will work out quids cheaper and depending on the quality of work put into it you could end up with an equaly nice if not better car see Fozzies
masterpiece in Kitcar mag. Oh and I truly believe there is a difference in pride at what youve achieved if you can actually say I built that from
scratch. Anyone can build a kit not everyone can make a Car
Hi
Well you certainly can not use the DAX chassis in the locost championship. Assuming thats why it's in 750 locost race issues section. However the
DAX is able to race in the KIT car championship or RGB. As works DAX'S run by Andy sterling have run in both.
Cheers Matt
