Looking for secure bonnet catches, as mine come unhooked all the time. Don't want to weld on tabs for pins or dzus fasteners, so what over centre design works best for you?
I was going to say dzus fasteners but as you said not too I won't!
this one
http://www.woolies-trim.co.uk/p-1537-over-centre-catch.aspx
has a little tab that sitcks through for a badlock, or split pin. maybe put a tie wrap through it to stop the latch passing over it?
^^^ I have those. Although they have a oostive lock, I use a small tube of plasitc and R clip to ensure there is no way thay can be undine.
Also at the front I have long spring loaded clips, I believe as used on Caterhams, again no probs with those.
If you don't want to weld lugs on to the chassis for Dzus fasteners, can you not rivet them on instead?
personally i looked at all the different locks and settled on aero Catches, Sikaflexed to the Bonnet, with brackest made up and rivnutted to the
chassis, once set up they are great.
I've riveted 'L' brackets to mine and used Dzus fasteners. Had loads of issues trying to get the 'clip-over' type to stay
down. (And that is before I've even got it on the road!)
[Edited on 10/8/10 by Daddylonglegs]
Hi
You cant beat the good old bonnet springs. As long as they are fitted and under tension you cant go wrong. Simples
Cheers Matt
Another vote for Aerocatches - secure and elegant
Thanks everyone! I've got a few things to think about now, but leaning towards the spring type. Hopefullly whatever I get comes before the next event!
received boot spring type in the post one week after ordering on fleabay. Excellent!!
I used these in stainless with the locking pins after my bonnet went into orbit. With a bit of jiggery poky they can be best placed to hold the bonnet
in position as well.
http://www.protex.com/product/show/name/270-600
