Hi guys
What the best way of removing the origional fuel conection point
As in the regs it has to be a screw in type union.
will it pull straingt out or does it have to be drilled
It should pull out with a pair of mole grips. They have been known to fall out which is why the regs insist on a screw-in fitting. Maurice
