I am taking car to be fine tuned on dyno, the engine has just been rebuilt by Vulcan but I had to fit the dizzy and do basic static timing Sanspeed has asked for any recommended settings for carb and dizzy in race trim, can anybody help, thanks
The camshaft manufacturer should be able to provide info on the timing set-up.
Do you know what camshaft Vulcan fitted during the rebuild?
Nick
yes it is the kent 102/104 the engine spec is for the locost 750 formula series
sorry, also the cam timing is all set, I just need the static tdc and twin choke carb jet sizes just to check, the carb was 2nd hand but apparently used in this race series
