hmm this could be a problem, I can't mind how to do that, e-mail query I got back -
Thanks for your enquiry.
Whilst a drawing will give us a good idea of the design you want we would not be able to make a cage from it.
We would need a drawing with 'x,y,and z' co-ordinates to produce a design without having your car.
Single diagonals in the rear will be adequate and a diagonal in the roof section preferable.
If you need any further info. please call.
Regards, Roger.
- any ideas???
[Edited on 29/5/08 by Mr Whippy]
is this a job for solidworks?
Maybe you could mock a cage up in plastic plumbing tube, that way they can take radiuses etc.
send me a copy of your drawing and I'll have a go with this if you like:
http://www.tekla.com/uk/Pages/Default.aspx
if you're stuck send me a sketch with dims and I'll knock up a drawing over the weekend if you like, shouldn't take long.
Thanks for the kind offers, much appreciated. Though I think I should have clarified that I haven't done them in CAD yet as I was trying to find
out first what format they required. I will however get right too work on it when I get home, should be a few hours work.
Thanks again
they just need the co-ords for the start, end and bends relative to a datum. It's not a format issue.
ok, hopefully from my 2d drawing someone could manage to do a quick 3d one
cheers
