what is in common use for coil/ dizzy set up for locost
Ernie,
Depends on what engine you are using. If you're using a crossflow, then the respective coil/dizzy for that engine or an aftermarket leccy ign set
would do the trick.
HTH
Simon
sorry, I should clarify, 750 locost race 1300 crossflow
contact ALDON AUTOMOTIVE they supply a brand new dizzy with optic pickup and high output coil. or sold as seperate items. just tell them its for
locost racing. most of the field are using there package and its verry reliable. not shure on price
ALDON AUTOMOTIVE 01384-572553
good luck mat
