do the same principles apply when using gunson eezibleed with twin master cylinder arrangement? eg just force the pressurised fluid to brake fluid
chamber?
is there a sequence of which calipers to bleed first or should i jack the rear up and bleed the fronts first? is 20 psi a reasonable tyure pressure to
use? cheers
Follow normal instructions, and know which cylinder is front do fronts etc
As above 40psi works better, a hose nipp can be very handy to control the air flow.
If you have oridinary tintop style hoses you can also use a hose nipp to control the fluid.
was just concerned about fluid flow out of the twin outlet resevoir,but i suppose if its pressurised it will pump equal ammounts to both cylinders
From my experience a normally inflated tyre is perfect (ie 25-30 psi) andything less than that and it will run out of puff before you finish,
(especially if your doing a full system after a fresh install or major works)
Do you have one reservoir serving both M/C?
i do mate. 2 x outlets from bottom
sorry missed the single reservoir point, even easier then..
but why would you you jack up the back to bleed the fronts?
All you need to do is wack the system on, bleed the one axel at a time (assuming you have a front/rear split), and just make sure you check the fluid level between each, as if it drops to low you will need to bleed them all through completely and start again!
just work them a seperate systems bleed one master cylider and its paired axle then refill gunson and do the second master cylider and its paired axle i normaly go for 20-25 psi but depending on the size of tyre you may have to pump it up half way through
The problem with using more than about 15psi is getting the eezibleed cap to seal on the reservoir, I always found more you woulod get fluid leaking from the cap/seal. Better to try with less pressure to start with IMHO
Don't even think about running it at over 20 psi or it will pi$$ out every where. At 40 psi it will blow it out all over you paint! 15 psi is more than adequate.
He cant do them seperately as he only has one reservoir to secure the ezibleed to!
Always had a problem with Eezi bleed getting to seal, leaking, correct pressure etc. Ended up buying a Mitvac works brilliantly.
took me a while to get a decent seal on my wilwood cylinders with the easibleed. ended up having to take another rubber seal out of the other caps to make it work, ended up with a resevoir full to the top and overflowing with fluid, and still didn't get the brakes bled. wasn't a proper effort on my part though, was just trying it out really, but with some care, they are very useful
Why not bleed them the old traditional way?
I have not any experience on easibleed, but i feel that while it requires only one person, it adds some complexity to the process.
it said on intructions that when using twin master cyliders to jack up the rear and bleed the fronts. thats why i suggested it.
