Im thinking about adding a big power engine to my formula 27, if I could get a reasonable amount of money for my engine/setup then I would definatly
go for it!
Its a 1600cc, 711m engine fully rebuild with all new gaskets and seals about 5000miles ago (although thats ~4 years ago now) with receipts for work by
engineering company.
Kent cams,
carbs
Unleaded conversion.
New pistons.
lots of burton parts,
4 branch manifold and exhuast.
4 speed box
new water pump
new alternater
uprated clutch
etc (need to check reciepts and spec when with the car next, but puts down a good amount more power than standard)
can come with full prop, rear axel, diff, loom etc if wanted so its litterly a drop in full setup.
Can be seen running before removal for a full inspection
im located in Bristol but can deliver at a cost anywhere if paid beforehand.
[Edited on 23/12/09 by ch1ef]
Just been let down on a complete 4AGE engine package, so U2U sent
researched what these are worth, seems an engine of this build quality sells for just under £1000, so im going to say £1200 for everything! Surely a
bargain?!
Will get full spec from reciepts asap and some pics
You might want to be a bit more specific about the parts fitted ('carbs' is a bit vague), performance etc, even a pic or two might help. I
reckon £1200 is pretty much the top end of the asking range, but others may have different opinions
[Edited on 23/12/09 by mr henderson]
thanks for the reply, get Ill sort out full specs, the cars locked in my mates garage that I cant get into or I would have done already, but will
soon.
for a drop in full setup, with carbs already setup and jetted etc for me if building a car would seem like a very easy and cost effective way to
go.
The full setup when I built it up cost me over £3000 including mates rates on engine building.
Bit silly of me putting this up with not a full spec. ill get it sorted and then hopefully go from there
did i read right been let down on toyota package, if someone had talked to seller and let him no what was happening then wouldnt of been let down.
handbags!
for anyone here for the sale thread, please see the other thread I started http://www.locostbuilders.co.uk/viewthread.php?tid=127244 to make it
clearer and with picture
happy christmas!
