selling my 50ltr 2HP compressor as ive replaced it to do my car spraying work as this one lasts 10-15 mins spraying at
this is the details below.... (no good for spraying a whole car)
Could deliver if local to my house or work or meet on route.
50 litre Electric Air Compressor
It works 100% and comes with 1 hose 10m and quick connectors.
1 down side. Its noisey.
Holds pressure for days no issue but noisey to fill up. Try keep in a box or in the shed rather than garage.
£70 ONO.
50Ltr 2HP 240v Air Compressor
For Home or Workshop;
Description:
Aluminium cylinder head with cast iron cylinder gives added resistance to wear. Suitable for general-purpose workshop applications.
Pump head directly coupled to heavy-duty induction motor for reliable and quiet operation. Welded tank complies with latest European standards. Fitted
with fully automatic pressure cut-out switch with twin gauges displaying tank and working pressures.
Specification:
• 230v/50Hz
• Power = 1.5kw 2HP
• 2850rpm
• Displacement of 206lts per Minute
• Displacement of 8.3cf per Minute
• Tank Capacity = 50lts
• Pressure = 8bar – 115psi
• Restart Pressure 70psi
• Weight – 42kgs Approx
• Dimensions: 77 x 33 x 73cm
• European Plug fitted, comes with adapter for UK use
2 x wheels
• Cable Length 1.8m
• Air outlet 1/4'' BSP
Message sent
2nd dibs please
USU sent
After this one sells guys, I've got one that I want rid of if anyone needs one
