Hi All,
I have for sale 4 x 17" 5 spoke style alloys, similar to Mk 5 Golf GTi alloys but with a split style spoke.
These good looking alloys were purchased new for £795 with tyres for my wifes Golf and looked great. They were fitted and only used for less than a
thousand miles due to a change of car!
5 x 100 stud pattern, that I believe fits most VWs, Seats, Audis, Skodas, Subaru Impreza and Toyota Celica, but please make sure you check your
compatibility.
They are in pretty much as new condition, and if there are any marks they are only from storage.
£350
I can happily email pics.
whats the offset ? and a pic would be good.
Hi,
They are away in storage but I am pretty sure that they are et 38.
I cant seem to get the pics to post, hence why I will happily email pics across.
Ah ha, worked out how to post pics now
Thanks but would need 53 ish for the scoob.
Actually I tried these for a photo opportunity on my classic and they fitted fine, but I had already rolled the arches for the 18"s that I
normally used.
Its a shame that you dont have the later brembos as I also have a set of 17" genuine STi alloys with Dunlop sports from my 2010 STi
Yep and what's worse is I am down your way the week after next as well.
Ah in that case it must be a sign from the Gods!
Upgrade to Brembos, or slightly roll the arches and thee shall be rewarded greatly
Yeh I want the brembo's hence the need for a high offset. Standard sti7~8 is 53mm
These alloys wouldnt fit if you had the Brembos as they would require 5 x 114 (unless they are the really old brembos pre 2003) .Thats why my STi alloys would fit as they are designed to clear the Brembos. I can get some pics if you interested.
All the new age impreza sti's had the brembo's and didn't go to 114pcd until the wide track blob eye in 2005.
In the UK, but different for certain jdm models and am models. So are you on the look out for early 5 x 100 brembos and rotors? I can see if anybody I know has any for sale.
Will be in due coarse as I have a vf43, bigger injectors, sti intercooler ect all sat in the garage.
There are that many being broken at the moment the bits are every where. There is a breakers in the next town that has ten sets on the shelf and there
are loads on ebay.
Ive only just put spanking brand new four pots on. I should have left them alone until I had saved up more.
