I know its a long shot, but don't suppose anyone based in the north east has a bearing that adapts the zetec crank to mate up to a type 9 input
shaft?
Im half way through swapping my blown up engine, havent got a bearing, can't get the old one out and everywheres's shut for 4 days
Please... Someone help!!!
Get a bolt thats a tight fit in the bearing, pack the bearing with grease put the bolt in and give a good thump with a hammer, should drive the bearing out. HTH Ray
Will try that after tea. Been trying hooking things behind it for hours!.
Thanks for the tip
No joy, tried everything and it won't budge. The full thing is ripped to bits and the outer casing is still solid in the engine. Looks like axle stands until Wednesday.
Pity that usually works a treat. Cheers Ray
Add some heat to the outer case the tap it out
No need now cos the bearing's no use and neither is the engine its stuck in.
