Hi,
don't suppose anyone has a 6" square piece of clear lexan or polycarbonate laying around? 2, 3 or 4mm would be ideal.
The piece I need doesn't really justify buying a full sheet.....
Phil
Hi do have 3 pieces in the workshop
will check the sizes , if they are ok you can have them for P&P
René
If René's are not suitable I think I've got some... used and may be 5 or 6mm though. Let me know
Simon
Well it is back to work tomorrow and if the previous posters don't work out I,m sure I can find a piece and get it through the franking.
Machine
Let me know
Atb
Mike
What are you going to use it for Phil? I have a piece of clear plastic 7.5"x6"x 4mm thick, haven't got a clue what material it is
though.
It's left over from the sheet I got to make side deflectors.
Hi
Sorry for the delay
I found them, the largest one is
210X148 mm X 2.15mm thick
or 8-1/4" X 5-7/8"
Brand new clear with the protective film
both sides .
Send me UTU with your name & address
if you want it, & I'll put it in the post
René
Sorry don't know the name just clear perspex looking with blue film.
[Edited on 6/1/14 by renetom]
